Patmasterflash
Hmm I stand corrected. I'm glad I read this before changing
Didn't read the whole thread but I actually replaced every single bolt with Grade 8 except uppers. That goes for Sway bar links, shocks, everything under.
Every trip something seemed to happen. Whether that was a trac bolt came loose or a sway bar link, almost everything did at one point. After the switch, nothing has and nor do I hear some of those annoying noises I used to. I tell everyone it was the best little mod I've done.
If you really want to complete the package, add some sleeves and gussets.
Sorry. I meant trusses, not gussets.
Checking the torque of your suspension components, prior to wheeling, was to difficult?
When you go every weekend, yes.
Northridge said I didn't need them by the way. They said the same things all of you guys are saying. I have not had anything come loose now. Before it seemed like every trip. Maybe it doesn't work for you guys, but it did for me.
Then a paint pen would have served you well. Torque it, mark it, check it visually..... Time and money saved.
:gaah: Way too much common sense there my friend. You might make his head explode. :crazyeyes:
Geez, you guys are brutal sometimes. All I said is it worked for me and for under $100 it's not a big deal. I do mark the bolts. It wasn't them coming loose really, it was more of them lost on the trail that made me look for a solution.
I know you wheel harder than most people and go a lot. It wasn't meant that you don't know anything. Sure, you can have the bolts even though I'm sure it was sarcastic.
That leads me to question how they were "falling out" if they were properly torqued. What specification guide were you using? What kind of torque wrench do you have? Where you using any kind of extension?
