thats more then a 1/4 inch if its that noticeable, and if you are going to quote me then read what i said... i said water is 2 lbs HEAVIER then gasoline :doh: good way to piss me off
When I turn right its stiff like the control are connected. When I turn left it leans even more like my control arms aren't connected. I plan on switching the coils around tomorrow. See if maybe that will help. What I can see from most people posting this this thread they assume quarter inch isn't a lot BUT that measuring it from the frame. When you look at the jeep from behind it looks a lot worse then it sounds. It's noticeable leaning passenger and it's not handling well at high speeds. This isn't an asthetic issue. There's an actually mechanical problem here.
So a 1/4" at the frame equates to a couple of inches at the top? Learn something new everyday.
so perhaps you should have eloborated that in your initial post and also maybe you want to throw in some measurements of the body as well...? By what you said in your last post, it sounds to me like maybe the shock on your passenger side has a blown seal. Try unbolting it and see if you can compress it easily by hand. If you can, then its a bad shock. If you cant, I dont know what to tell you.
:cheesy: I honestly laugh cause that's about what I was about to say. More rather, I was going to say, "I bet it looks pretty level with you sitting inside your Jeep."
So much stupid in this thread!
Amazingly
Expensive
Vehicles
Move your tool box over a foot and drive that shit! Lol
Those of you who had actual constructive comments, appreciate your help.
Maybe you should read what I said. I made a point that I'm heavier then 144 pounds. If anything its should level out or lean the other way.
You're complaining about a quarter inch? I'm getting my new suspension soon. Mine sits at like 2 inches lower on the side literally too pictures and I have 8 inches between tire and body on the driver side and 6.25 on passenger.
dude... its a quarter inch...
