JK quick disconnects passenger side too tight?
jorgelrod
I just installed some Rough Country quick discos in my JK but I find that removing the link in the passenger side is going to be a pain because the space between the trackbar mount and the link pin is kind of almost to small. Any hints or tips??
this is normal. you should be able to fit the bottom of the link inbetween that space just fine with no issues. i was able to fit my jks links thru there with no issue.
As mentioned, it'll be close but it'll come out. Install can be a bit tougher especially if you're not on level ground but, it can be done without too much fuss too.
