So after jacking this back up and looking at some more threads I noticed the front track bar bushing and bolt on drivers side would move around when i turned the wheel. I was told this was an issue with the stock bolts being to small. So I ordered and adjustable track bar, with the upgraded M14 bolt kit as well as a new terra flex front steering stabilizer. I will throw this on and see if The issue is solved.....
Glad you found that one of your bolts were loose but there is nothing wrong with its size - it simply was loose. The following links should help educate you better on the matters you're dealing with.
https://wayalife.com/showthread.php...ade-8-Replacement-Bolts-Do-I-Really-Need-Them
https://wayalife.com/showthread.php...s-What-it-isn-t-and-What-You-Can-Do-to-Fix-it
