OverlanderJK
Resident Smartass
I will add this to the list of parts to buy when I do the motor swap. Glad it keeps it cooler!
Dang, that is awesome. Great idea with the JL fan, they are monsters. Pretty cool idea for the trans cooler and while I think it will hold up well too, I hope it does. Glad to see moby getting all this love, one bad ass Jeep!
Big brother taking a page from little brother. Awesome. And why am I not surprised you guys pushed him over 100mph. But I just say, the fact that you were able to safely drive at that speed is a testament to the work that ORE does and the quality of their designs. Super cool.
Sweet. Thanks. Very affordable too. I have another Winter project now.
I have 2 OEM coolers as well but going uphill in the summer with gear/tools, larger tires, etc, I can feel a ton heat from the tunnel that I didn't used to.
Glad they got it to work!!! I’m excited to see how the transmission coolers survive the JKX
Nice with the 37s I’m having to turn off AC on long climbs now . Do you have recommendations or links to what you used to run for trans cooler ? Would buy off that if it would help the forum . Also what is that temp gauge ? I hate how the favorite Gauge is fake and doesn’t move until its already hot and jumps straight to 3/4 . Any other tips to keep things cooler ?
That gauge is the Aeroforce gauge. I love mine and keep it set the same way Eddie does with trans and oil temps. It makes you a bit OCD always checking them, but it’s good to know exactly how it’s preforming. For oil on a 90+ day on the highway, I’ll run around 220-230 up long grades and hold around 210 flat. Trans will run around 198-210 on grades and usually holds at 192. That’s doing 75 for sustained periods of time with the AC on. On cool days it’s usually 176 trans and 204 oil. Great little tool. It’s interesting, with the top and AC off and the numbers are the same. A lot more drag with it opened up. On the trail at slow speeds it usually holds at 167 and 201.
That’s outstanding! Is the JL fan a lot louder than the Camero fan? My dads JL 2.0 L fan sounds like a small plane taking off when it ramps up.
I’m glad to hear that the trans is staying cooler [emoji106]
Hmmmmm....
Trans cooler makes a big difference in fluid temps...wait until you get that oil cooler hooked up...your coolant temps should lower also.
I’ve got fans on large oil & trans coolers on my JK6...I’ve never seen coolant temps over 212 or trans temps over 190...but I also don’t have ac (there was no room for it in the engine bay...
Can’t wait to see pics from the last JKX run...good luck!
Eddie, thanks for posting this and thanks that you [inadvertently] helped me make huge strides in all the issues I’m having with my build.
I have two threads on here about some overheating issues I had on my trip to Moab last month as well as some performance issues with the LS. Because Moby was at Motech at the same time as mine and had a similar build (similar, not exact...we covered this) Robbie was able to do some side by side testing. The result was him acknowledging that there is in fact something going on with it. He loaded your tune in mine and Moby is noticeably quicker/more responsive.
Anyway, glad this helped the cooling issues and looking forward to getting mine back with similar updates. Also hoping they find the issue that is causing the sluggishness but confident they will.
Cool
The JL fan means business. Looking forward to the JKX highlights.
That’s awesome that the JL fan worked out for you. Every time I hear a JL fan running I wonder how well it would fit in my WJ. I currently don’t have any over hearing issues, but I’d rather be safe than sorry.
Sweet!!! So cool that the fan works harder and pulls more air then the camaro one did. Glad to see the temp results are working as well.
Yeah, been long overdue. Moby is 12 years old now and he's starting to show it. Hoping all this love will get him running like new again. :yup:
LOL - it's what family does and yes ORE does good work
These coolers do solve the problem of where to put more cooling. Hope they work out for you as well
Me too. If all goes well, this will be a great solution for others
How hot are you getting? The JK with a 3.6L likes to run hot and having to turn off the AC to keep things cool on a long climb is kinda normal.
Yup, it's an Aeroforce gauge. Works well
LOL - giving you some ideas?
Is there an actual size difference between the JK and JL fan diameter or just blade/programming differences?
Would the JL fan work as a replacement for a JK if the JK fan fails? It's probably expensive enough that it's not practical just for "Upgrading's" sake, but if my fan ever failed, it'd be interesting to know the bigger JL fan is an option.
I don't think so or at least, not on a JK with a 3.6L. The Pentastar works off of a different programming. This is why Motech typically uses a Camaro fan. Fortunately, the JL fan works like a GM fan and so they were able to just bolt it right up.
I am running the same 6.0 and 6l80 setup from motech in my jku. Is the additional trans cooler plumbed into the return line from the other trans cooler on the radiator? I want to do this also since I’m having the same heat issues.
