Leaking axle seals again
sipafz
Roughly how much should a shop charge me for that? Don’t wanna get screwed over.
Sent from Lookout Mtn.
My best guess based on a $90hr rate (which is the rate of the plater I use in Milwaukee):
45min pre-grind $67.50
Chrome (mask & plate) $75
1hr finish grind $90
Total = $242.50ea
For comparison, the rate of my machine shop is $180/$250hr depending on the process which is typical in the industry. Add markup for the outside processing (plating) and the cost doubles
If you decide to get a quote, I’d be interested to hear about it.
Bierpower
One thing you may look into also is what they call a repair seal. They are pretty common on semi-float rear axles. They simply move the contact patch of the seal over 1/8"-1/4" so that it's not sitting on the groove.
Red Knight15
Total = $242.50ea
Interested to see what kinda quotes in Alabama. Hopefully I can get a good deal with one of them, we send stuff to them for repairs from work. Thanks for your information.
BlueRubicon
1500 miles and my new seals are leaking already. 35 Spline Nitro shafts in ProRock 44.
Noticed this groove worn into shaft when I replaced them last time. Thinking that’s the cause of my leaks. Shafts have roughly 27k on them. Anyone having issues with this?
Have you called Dynatrac?
Red Knight15
I haven’t. It has Nitro axle shafts so it’s a shaft issue not the housing. I’m probably going to buy a new set of shafts and get these repaired. Most likely a different brand. It’s a driver now, sold my tow rig last week. [emoji23]
jesse3638
I'd go with the USA made Revolution Shafts. They come with a lifetime warranty even on the u-joints. Its what I put in my stock axle. Have you contacted Nitro to see if they'll warranty it?
Red Knight15
I have the Revolution Shafts in my rear axle and that’s what I will buy for front.
I’m gonna try to contact Nitro today. Pretty sure they aren’t under warranty , I’ve had them 2.5 years.
jesse3638
Yeah I've got them in my real axle still. RCV's came in the used PR44 I just installed. If those start clicking or giving me issues I'll get another set of Revolutions.
BlueRubicon
RCV's are lifetime warranty and made in Illinois. You can send them back to RCV and they would probably replace.
Revolution seems to me to be a'supplier'. They dont manufacture. RCV manufacturers for lunatics like us who break shit.
JKbrick
I noticed while looking at axles they have rear axle shafts too now
wjtstudios
They won’t warrant them for the “clicking”, but they will rebuild them for you for a fee
2015 JKUR AEV JK350
1985 CJ8 Scrambler
MericaMade
Let me start by saying I cannot confirm but I was told Nitro was saying some pretty bizarre stuff on Facebook backing Antifa. Anyone else hear or see this?
Sent from my SM-N975U using WAYALIFE mobile app
