jksmith93
I am planning in the near future to lift my 2012 JKU. I've done a good bit of research but I'm searching for a few more opinions. Backstory: Ive got a Teraflex coil spring spacer lift/leveling kit currently on my Jeep, with 2" worth of pucks up front and 1" out back if i recall correctly. I'm wanting to redo/add to my lift with new coils and shocks, etc. I know you all like your brands but I'm not here for a lecture on what parts to use, I'm on a budget so I'm going to go with a Rough Country lift. I plan on getting a Rough Country 2.5" lift with the 2.2 shocks. This kit comes with all four new shocks and four lift coils. However, there is a 3.25" lift that comes with what seems to me to be the same exact coils and shocks adding in some coil spacers to tack on the extra lift. I'm planning on leaving in my rear spacer puck from my Teraflex kit, and leaving one of the 1" pucks up front to basically add to the 2.5 kit, what they seem to be selling me with the 3.25. Am I making correct assumptions here thinking that this will work? I've sought advice with a local off road shop and the owner, who is very well versed, seems to believe this can be done without much issue by his shop, however, like i said I'm on a budget so I'd be doing all the real work, minus the alignment myself. Also, in regards to the small metal track bar bracket pictured in the 3.25 kit, I can do mild to advanced metal fabrication on my own so I'm thinking something could be mocked up custom, along with the brake line brackets.
Sorry for the lengthy post.
Also, I'm running 33" tires if that's a question.
Teraflex leveling kit (currently installed):http://www.quadratec.com/products/1...oglemerchant&gclid=CI7r69Ou2LUCFQ2nnQod1kkA5A
Rough Country 2.5 lift: http://www.roughcountry.com/jeep_jk_2perf.php
Rough Country 3.25 lift:http://www.roughcountry.com/jeep_jk_3.html
