shadowpaige64507
Okay, what should it look like?
If after driving you still have chalk on the outside edges of tread, than you still have to much pressure.
Now that you have received advice regarding the tire pressure, are you still wanting a 3 inch lift on top of the 2 1/2 inch body lift for your 33s?
So I've been running my 35 trail grapplers at 37psi on the road should I lower them to 29?
I'm running Nitto Terra Grapplers 33s with about 60 psi
Just for refference sake, I found that 28psi is the best for my 35s.
Your tires aren't rated for that kind of pressure.
They surprisingly are. Max PSI on that tire is 65 PSI, unless I read it wrong from the Nitto website.
That is the maximum allowable working pressure. It does not mean to run them at MAWP.
Correct. The comment I replied to was in regard to 60 PSI being out of the MAWP of the tire, when in fact the MAWP is rated at 65 PSI. I was not endorsing running this tire at that much PSI, but saying that 60 PSI is above the MAWP is not an accurate statement....according to Nitto. Go back a few pages and read my reply from earlier today. You'll see that we are on the same page.
