Low Budget Willys Crawler
BABOOZLE
Started doing a little body work/paint prep while I wait for parts to show up on CL.
The fenders have cut, reshaped and welded back together. And as you can see, whoever welded this looks like they did it with a potato. IMG_0890.jpg IMG_0891.jpg IMG_0892.jpg IMG_0893.jpg
After going over these I found a lot of thin areas, rust and bondo. I don’t think I’ll save these and I will run with no fenders or with tube fenders.
I-Eat-Mud
Badass project man! Those welds look rough though, looks like somebody gave me tequila and let me near your jeep with a welder. (don't ask me how i know what that looks like)
BABOOZLE
Sold the wheels for the Willys to a guy that drove 2 hours and met up with me at 5 am before I went to work. More money to add to the parts pot. I also have a lead on a Dana 60. IMG_1020.jpg
BABOOZLE
This past week I’ve been working on painting the Willys. As you’ve seen from the fenders, the body also has some character. I wasn’t a fan of the red so I decided to give it a little change up.
I wanted to go with a patina/old farm truck theme. I chose to go with blue as a tribute to my grandfather’s old blue 1970 F100 that he drove every day. This whole paint job was an experiment and it was very fun to do.
IMG_1021.jpg Got everything sanded. IMG_1024.jpg Grabbed some International Harvester paint I had and rolled it on. I didn’t need to hit it with red again but I wanted to roll the paint on to give it some texture. IMG_1026.jpg IMG_1028.jpg IMG_1029.jpg IMG_1031.jpg
Next I hit the body with some brown for an added color. If I was going for more of a rust look I probably would have mixed a brown and red to try and achieve that. IMG_1034.jpg IMG_1035.jpg
After that, it was the blue. IMG_1037.jpg IMG_1036.jpg IMG_1050.jpg Next I lightly dusted them with white to give them a chalky look. IMG_1038.jpg The final part was wet sanding. You can’t really mess this up. Just sand until you get the look you desire. I really like the look of the red coming through. Plus there was some really good texture in the paint. IMG_1042.jpg IMG_1045.jpg IMG_1047.jpg IMG_1053.jpg IMG_1054.jpg IMG_1067.jpg IMG_1068.jpg
This paint job is not for everyone but I like how it turned out and it was fun. I can always add more character later.
fiend
View attachment 302375 Got everything sanded. View attachment 302377 Grabbed some International Harvester paint I had and rolled it on. I didn’t need to hit it with red again but I wanted to roll the paint on to give it some texture. View attachment 302378 View attachment 302379 View attachment 302380 View attachment 302381
Next I hit the body with some brown for an added color. If I was going for more of a rust look I probably would have mixed a brown and red to try and achieve that. View attachment 302382 View attachment 302383
After that, it was the blue. View attachment 302384 View attachment 302385 View attachment 302386 Next I lightly dusted them with white to give them a chalky look. View attachment 302387 The final part was wet sanding. You can’t really mess this up. Just sand until you get the look you desire. I really like the look of the red coming through. Plus there was some really good texture in the paint. View attachment 302388 View attachment 302389 View attachment 302390 View attachment 302391 View attachment 302392 View attachment 302393 View attachment 302394
Cool project. Did you apply the brown and blue by spray gun or by roller and brush? All the sanding was be hand?
BABOOZLE
Finally back to work on the Willys. Doesn’t have a name yet. I’m open to ideas. I’ve been searching for a cheap 60 for a couple months with no luck. So to get this project moving I decided to just run a 44 up front for the time being. The issue with the cheap 44 I bought for mock up is that it has drums. Didn’t want to spend the money to convert or go through the hassle of doing it so I found another GM 44 that is 8 lug, disc brakes, 4.10s and a broken stub shaft for $100. IMG_1662.jpg
The broken shaft was caused by the gears being welded together. I don’t plan on running it like this forever but I may keep it for a little bit since I have selectable hubs. Klungly gave me an extra carrier which I will have in the future. IMG_1665.jpg IMG_1666.jpg IMG_1667.jpg
BABOOZLE
Since I have the extra 44 I was hoping that I could use the axle shafts to replace the broken ones. The inner axles are the same length but the stub shafts are different lengths. Looks like I will need to buy one. IMG_1668.jpg IMG_1669.jpg
One thing the old axle was good for is that it has flat top knuckles. Which means I can covert the steering to a high crossover type steering. IMG_1671.jpg More to follow on that.
BABOOZLE
Alright, finally getting back to this project. None of the donor parts from the older D44 worked with the newer one. Axle shafts are different and the flat top knuckle doesn’t work with disc brakes. So I bought some new 4340 shafts from ECGS and knuckle setup for crossover steering. IMG_2954.jpg
I think I will go with 4.56 gears and a Detroit in the rear. The front will remain open until I can buy a selectable locker up front. A little progress.
catahoula
Just saw this. The paint turned out awesome.
BABOOZLE
Awesome project. Can't wait to see it done.
Thanks!
Thank you. It was a risk. I’ll do some more sanding once it get it put together.
Great looking build so far! The paint looks sweet, are you hoping to have this up and running for ejs 2019?
Thanks! I wish it would be ready but my work schedule will most likely get in the way.
BABOOZLE
Update. Bought another chromoly shaft to complete the D44. Also replaced the bearings, calipers and rotors. IMG_3193.jpg
Got some metal from klungly and finished boxing the frame. IMG_3432.jpg IMG_3434.jpg IMG_3498.jpg
Got a one ton tie rod kit from East Coast Gear Supply and welded that up as well. IMG_3395.jpg
BABOOZLE
I finally put the cab on and as I expected I won’t be able to get it out of the garage unless I flatten the tires. It is a monster. Plus the put some ratchet straps on the rear and brought down the rear on the frame until the springs were almost flat. There’s still a pretty big rake to it so I might do a spring under in the rear which will fix the rake and I won’t have to worry about axle wrap as much. IMG_3501.jpg IMG_3504.jpg IMG_3510.jpg
Jsouder53
I finally put the cab on and as I expected I won’t be able to get it out of the garage unless I flatten the tires. It is a monster. Plus the put some ratchet straps on the rear and brought down the rear on the frame until the springs were almost flat. There’s still a pretty big rake to it so I might do a spring under in the rear which will fix the rake and I won’t have to worry about axle wrap as much. View attachment 315237 View attachment 315238 View attachment 315239
That’s going to look so good when it’s complete [emoji106]
