MSJKU11
I don't need to regrease for a little while anyway right?! [emoji23]Oh no.[emoji25]
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Sent from my SM-G965U using Tapatalk
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Are you saying that your top ball joint is so loose in the knuckle that you don't need a press? If so, you might need a new ball joint and/or a new knuckle depending on what's that worn out. [emoji15]So question. This only happened on one ball joint but its loose and I didnt have to press it in. What should I do? It's the top ball joint.
Well the ball joint is a new prosteer. Weird it only happened on one. The ball joints coming out look identical. Is this where a knurled ball joint style is needed?Are you saying that your top ball joint is so loose in the knuckle that you don't need a press? If so, you might need a new ball joint and/or a new knuckle depending on what's that worn out. [emoji15]
Possibly, but I'd probably replace the knuckle.Well the ball joint is a new prosteer. Weird it only happened on one. The ball joints coming out look identical. Is this where a knurled ball joint style is needed?
But I already reamed this one for my tie rod and drag link. I don't wanna do that again! [emoji24]Possibly, but I'd probably replace the knuckle.
That would be great. Man you really help me out alot lol.I have a knuckle that the drag link hole is drilled for a bushing for a flip kit if you need it
Thanks Mark. Let me know what I can send you in return.
Oh you're right! Don't worry about sending it then. I'll call dynatrac Monday and see what they recommend.I just thought of something, if your ball joint is loose that is your axle not your knuckle, but if you need it I’d still send it to you
That was easy!!!! Only problem is Dynatrac has an 8-10 week backlog on new axles.
Scored this jeep from a neighbor. This kid is in heaven right now. Already tried crawling over a pile of branches while I was doing yard work. Love this kid. View attachment 350306
