wjtstudios
Awesome, down to days now!!
2015 JKUR AEV JK350
1985 CJ8 Scrambler
			2015 JKUR AEV JK350
1985 CJ8 Scrambler
Sorry late to the topic, but if it’s loose you can stake the hole with a chisel and punch and then press it in. Looks like you found a better option anyways.
I'm getting the knurled version from dynatrac.
That was easy!!!! Only problem is Dynatrac has an 8-10 week backlog on new axles.
Do you need a PR44? I might be able to get you one a lot faster than that.
Yes, increasing lower arm length or decreasing upper length will increase the negative caster - it’ll roll the axle back toward the cab which will increase your angle.
Toe is a little out also...time to get out the yard sticks again! [emoji23]
Unfortunately I didn't find this out until I got home. Going to pull them off and put them back on correctly. I should have just done it myself and brought them to just balance.I hope you don’t drive around with those wheels on there. I would also not want to be anywhere near that when it’s filled with air. And lastly, never go to that shop again as they will kill someone.
What in the actual fuck? Unless I’m seeing the pics wrong, that shop has no fucking clue how a beadlock works.
NiceBought and installed an air compressor.
It came with the syngery mount. Fits nicely under the hood on the driver side. Sure beats my little vair 88.View attachment 354198
Sent from my SM-G965U using Tapatalk
I probably would have never noticed that but yea, it's off. That's what I get for not paying attention to what I order. I don't think it's a real PS louver.Is it just me? Or is it just the angle of the photo?
