Speedy_RCW
No. I bought a 20" Wetsounds sound bar I'll install on the rear upper C pillar cross bar facing forward. Thats the plan, I'll have to see how the head room with rear seats works out. While the soundbar doesnt have as much low end as the factory sound bar, I do have a factory rear sub, so I hope it ballances out OK. The factory sound bar can be reinstalled, but takes some cutting to make it work. The wetsounds bar will be a cleaner look.
Also No on the trim. I'll finish bed lining the inside where trim was. I may keep some around the windshield frame. The sun visors kind of tie into the trim. I'll just have to see what I end up doing with it.
This cage is obviously much heavier, taking the trim and seat belts out it may not end up being heavier in the end. I am keeping track of the weights so I'll have an actual answer soon.
Gotcha. I’m interested to see the WetSounds bar installed. Please post that up when you get it done. I did the same cage (minus the x-bar) and went back and forth on what I wanted to do for speakers and ended up re-installing the factory sound bar which also gave me the dome light back. Most of the trim I was able to get back in (with a bit of Dremel work) except for the upper B-pillar.
