Ok… back when I was greener to the Jeep than I am now, I had the dealer install a new AEV dualsport 3.5”/4.5” lift. They said if they do that lift it wouldn’t void my warranty so I paid too much and let them do it. Seems all I got out of the deal was some springs, brackets and shocks. Feel like I’ve been took…. But it is what it is and moving on… So, my question to you all is this:.. should I just chuck it and get a better lift package installed? Or just keep what I got and improve on it?... Like, what would it take to modify it to a 4.5” so I can run 37”s comfortably? Also, I think a better set of control arms and maybe HD steering system components.. and down the road, replace the shocks?.. I want to save a bit of money and not buy the same thing twice unless it is wise to do so.. I am also wanting to upgrade to new duratrac axles. (Daily driver, want to do a bit of wheeling a couple times a month, but drive mostly highway miles… rubicon 4 door, 2016.).. just want some beefier parts.. but only the ones that make sense to do right at this moment.
The fanboys on here will tell you that the AEV Dualsport is the best thing since sliced bread and really, what would you expect from someone who paid a boat load of money for springs, shocks and relocation brackets. Not that any of that is bad per se but yeah, you paid way too much for how little you actually got.
Based on my test of the kit you have, I would probably recommend that you get a complete new kit unless you happy with the stiffness of the coils you are running. The drop brackets are just a cheap solution to address what adjustable control arm would do and do better. If you decide to get adjustable aftermarket arms, do yourself a favor and DITCH the cheap flimsy bracket that will bend and can break. Trust me, I have seen it. As far as things like sector shaft braces go, people who don't have any real experience will recommend them because they don't know any better. They were highly recommend back in the TJ, YJ and CJ days when steering boxes would tear off the frame but the JK frame is strong enough to support the steering box and the only sector shaft breaks I've seen had to do with rotation and NOT side loads. If you're really worried about a sector shaft break, do yourself a favor and install a ram assist.
Regarding a HD steering system, all you really need is a good HD tie rod as the factory one is very weak and will bend at just about anything. The factory track bar and drag link are fine especially if you run a ram assist. Certainly, they are what I still run but then of course, unlike some of the other experts here, I'm just a mall crawler so you can take what I say for what it's worth.
