JeepRubicon99787
Can you reproduce the squeak with your Jeep parked or do you have to be moving in order to make it happen? In other words, can you or a friend rock your Jeep back and forth or bounce up and down on the bumper to make it happen? If so, have someone do it while you lay under your Jeep looking for the sound. A creaking like this will cause whatever is causing it to vibrate so touch things like your control arms, shocks and sway bar links and the sound is being made. Whatever is vibrating the most is probably where your problem is. If you have the TeraFlex control arms, you may have a bushing that is dried out and/or blown. A dry sway bar link bushing can cause this sound as well and a polyurethane shock mount can as well. This is where I would start looking.
Well, I get the sound when i move from stand still or going over a speed bump. I don't have any vibrations though.
I did try and rock the jeep side to side and get the same sound but slightly.
The arms provided are from TF but non-adjustable..
I just got my jeep back and will try and locate the source..
