utiadam
LOSER
A beautiful example of built not bought!
Very true!!!
Thank you both!
Very true!!!
This is what I used under the armor:
The installation of the dynamat was very easy because I didn't have to clean any of the surfaces because the jeep was so new. The carpet comes right out as well. The cheapest place to buy it is on Amazon. It's about $140/bulk pack. I used about 4 bulk packs.
Ok great thanks for the info! Could you possibly compile a list of links for me of what I need from amazon. I see they have dynamat tape and install roller do I need them? Also should I also use the dynoliner after? what is it for?
Thanks again.
Front 2 are installed
The corners weren't that bad to install. You definitely have to use ratchet straps to press it against the body. I still need to figure out my tail lights. The turn signals are blinking fast even with the 6 ohm resistors installed.
No clue how many ohms these guys are, but you could always give one of them a shot since they're not too pricey.
LED Resistor Kit (for JK LED Taillights)
My Billet Rubi turned 30k today
