Mybadjk build
TrailHunter
Looks great man!!! My buddy said you guys were pretty focused.. and no beer was involved.. lol... (your wheels look a little shinier than mine [emoji51])
Mybadjk
Well talked to dynatrac, going to finalize my order tomorrow. Rubicon axles are pending sale. Planning on changing diff fluid in the xd60 tomorrow, install my four other Kc cyclones.
So planning on an xd 60 front with an arb but going with the nodular iron knuckles. A little more of an upgrade from a normal pro rock. To me the little more for .65” bigger tubes and a 10.1” ring gear instead of the 9.75”. Even though I figured I wouldn’t have a problem with either set up. Going to run it without hydro for a bit. I’ll do 40s and hydro later on.
Jsouder53
Sounds like an awesome plan! Definitely a good upgrade from the normal pro rock [emoji106]
Mybadjk
Thanks guys!
Got around to changing the diff fluid. Kind of a pain. But after the fluid change I remembered I had the pump for the bottles. Lol
Also got my spare mounted, need to trim the bracket some more. Also got my beadlock done that was missing the coil insert.
Thanks guys!
If you use the pointed tips on the bottles, no pump needed. Super easy and no mess. You can do the same on the transfer case.
Mybadjk
Well meant for the sumo for the pinion. The bolt is against the gas tank so it’s tight. Had a tube connected to squeeze it in there.
Mybadjk
Well while I’m waiting on my axle being built. I’m getting impatient and wanting to many things and once being indecisive. Lol told my sell I’d wheel the xd60 how it comes with 37s for a bit. But now I’m looking at hydro and the evo high steer kit. Thinking I may be able to save a bit by not getting the brackets on and just going with the evo high steer.
Talked to bubba as well as Mel. Afterwards I had a couple thought come up in my head. I’d say they sound crazy. Lol I guess I got seven or so weeks to think about it..
