NEW!!!! 2" SPORT system with progressive coils front and rear!
JK Todd
Long time lurker, first time post. Look forward to availability just the springs. Matt, please continue to keep us informed.
Sharkey
Word Ninja
Strange question for you Rancho. I have this kit installed with the RS9000’s. Everything is great but I’m thinking about putting a .75” spacer in the rear to get the rear end up a bit. I also was gifted (but haven’t installed) some EVO Rockstars that I believe raise the lower rear shock mount by 1.5”. If I put both the rockstars and the .75” puck on, would the RS9000’s that came with the kit still be within the proper tolerances in terms of full drop and compression?
I hope that all makes sense.
cozdude
Guy with a Red 2-Door
Yes they should be. What you can do sharkey is install the spacer and then measure the exposed shock length and compare it to the distance between the bump stop. If you have more than 1.5” of shock length showing over the amount of space between the bump stops then your good.
That make sense?
Rancho
What @cozdude said.
We usually suggest a "shorter" shock with the Rockstars, but the spacer "bumps" it up.
So good to go.
:beer:
That make sense?
Arrcherr
I'm glad you asked this question. I've been looking at Evo and rancho kits for a while now but I'd really prefer to get one that lifts front and back the same or at least close to the same height. A spacer seems like a good solution if there isn't a kit available.
Sharkey
Word Ninja
^^ This Rancho kit does lift the front and back pretty darn close to an equal amount when it’s all said and done. We just want a tad more from the back because of all of stuff (tools and gear) we have in the back. Also, we have a 35 on the back which is a bit more weight too.
Arrcherr
Ok sounds good, thanks for the heads up!
WanderlustSW
I'm thinking that this is the lift I'm going to go with. Will I need extended brake lines, or track bar? I'm planning to run 315's will they rub, or what backspace is recommended? Anything else I'm missing to complete the lift? Thanks
cozdude
Just installed this lift on @cyoung16 parents 2016 2 door at work today and I have to say I really like it! Easy install and rides super nice!
Some before pics of it next to knuckles
Lift going on
After!!
The Jeep is completely stock outside of the lift so it netted about 2.5” to start. I’m sure it will settle a bit. Also set the front shocks to setting 1 and the tears to 3 due to the hardtop adding the weight. Next will be some 35’s!
WanderlustSW
Lift going on
After!!
That looks great!
Mikecal9985
Would this be considered a leveling kit? I used to have the teraflex puck leveling kit and it raised the front 2” and the rear 3/4”. I noticed these are the same measurements as this kit. Just wondering
Rancho
Yes we consider it a level, but it does lift the JK.
And yes we have an option for the JKU.
It should sit pretty spot on, but every JK is different.
For example I am about to refresh my JKU on a 4" lift.
I ordered a bunch of different spacers to add to out coils.. Why? I am a big boy JKU, I carry a lot of weight, I want to see where I sit loaded down and go from there.
If I un-load, and sit up high, I am fine with that. :icon_crazy: #stinkbug
@Rancho, this kit is available for the 4dr as well correct?
Arrcherr
The Jeep looks great, awesome that it's springs front and rear and still doesn't net too much height. Perfect for a LCOG build. I'd be curious to see it once the 35s are on it.
Sharkey
Word Ninja
It looks like this. ;)
Stock flares.
Cut stock flares.
In the process of aftermarket flats from Fishbone.
catahoula
