New Rig - Silver Bullet - DTD, 60/80, 40’s....
OverlanderJK
Resident Smartass
I’ll give you 1,500 for it when you can’t get it running.
You’re going to come up and finish it when I can’t get it running.
Be careful with the fuel line connections..
Already have extras just for that reason. [emoji1303]
So what you’re saying is that you are just ok with doing engine swaps...
That’s giving me a little too much credit. Lol
Good luck, man. Make it happen and stay safe. And have fun finding a storage spot for the hoist when you're all done.
OverlanderJK
Resident Smartass
How anyone does this shit without child labor is beyond me. You need some small fucking hands that have the strength of Arnold in his hay day.
Just need to disconnect exhaust and some more wiring and it should be ready to pull.
Power steering pump can suck my balls.
CalSgt
Just keep at it & call it dirty words to establish dominance, looks like you've made good progress
Bullwinckle
Looks like your getting a lot done. Just keep saying to yourself it will be worth it in the end. lol [emoji38]
OverlanderJK
Resident Smartass
Had to do my chores for a couple hours. Back at it. Just need to unbolt from the trans and pull this biotch.
OverlanderJK
Resident Smartass
Looking good. You think you'll be able to slide it up and out with the radiator still in there?
I’m gonna try. If I can get the trans bolts out. What a bitch.
I should be able to I’m hoping. I can always let the air out of the tires to lower it down some more if I need to. Worse comes to worse I’ll pop the radiator out. It’s only a couple bolts at this point.
JKbrick
That looks like quite the project. Are you going to rebuild the one your pulling out for a spare or is this the last v6 for it?
OverlanderJK
Resident Smartass
This is for sure the last V6. I found the issue I was having. Wish I had found it before because I would have pulled the motor yet.
The PCV hose disconnected from the rubber coupler at the back of the motor.
Hardest part of pulling any engine it seems. Those things suck to get to. Sometimes dropping the trans mount down helps to tilt the motor but it's just more steps to do.
Yeah that’s where the oil came from.
Install a catch can back there :cheesy:
OverlanderJK
Resident Smartass
I looked online a bit and saw some people disconnected the motor mounts first and hooked up the engine to the hoist and lowered it slowly to get to the back on the motor. I’ll try that tomorrow.
