New Rig - Silver Bullet - DTD, 60/80, 40’s....
I can honestly say that isn't a job I would look forward to doing :crazyeyes:
Looking forward to seeing that thing back out on the trail again :yup:
2nd.gunman
I guess as long as you don’t need to pull the trans into the back off the engine with the bolts you should get away with it. If not you might need to turn the crank to get it too seat properly.
OverlanderJK
Resident Smartass
After putting the motor in and taking it out repeatedly I am finally making some progress. Mated the motor and trans and two of the flywheel bolts installed. Hopefully I won’t have to take it out anymore.
OverlanderJK
Resident Smartass
It’s in. And on its own weight.
I feel like I’ve completed the easy part. Hard part is hooking all the wires up.
OverlanderJK
Resident Smartass
Did you mark everything or take a lot of pics before you started?
Uh no. Why would I make it easier on myself?
Hopefully I don’t jinx myself but the harnesses are only so long. Most plugs just line up due to length. It’s not super hard.
Most of the wires are hooked up now. Need to do a few more things tomorrow and I should be able to fire it. Then have to redo all wiring and install the switch pros.
