I've never had a problem since I started using these...
You sure the porcelain isn't cracked? I've used these on at least 6 or 7 installs over the last few years and not one leaked.
Did you add a layer of tile or anything? The collar should be sitting on top of the floor surface or a regular ring will not be thick enough to reach the bottom of the bowl
It has tile. The collar is level with the floor right now and that’s how the old one was. I’ll probably grab the extra thick wax ring today and install that if I have time. It’s the spare bath luckily so I don’t need it. And I have a dining room table I need to finish that’s more important.
Employees who work from home and are late to clock in.
How the fuck is that even possible?
When you gotta poop you gotta poop bro.
That should work if the top of the collar is flush with the floor just use the thick wax ring. If you feel it squish into the wax your good
If they don't have the thick wax you can double stack two regular ones. Should be good to go as soon as you're finished.It is. I’m gonna go get the thick wax ring now. Do you have to let it set before you flush or is it good as soon as you set it?
^^ what he said, good right away. If you have to stack them put one on the bottom that doesn’t have the horn, then the top one use one with a horn
[emoji23][emoji23][emoji23][emoji23] sorry but that’s so dumb I couldn’t help but laugh. I don’t know how the hell that’s possible
No shit, I even had one say they had the shits and couldn’t work. Hello perfect time to have them at home!
