PRESS RELEASE : Superchips TrailDash $100 Off Promo!!
TeamFaust
Was curious if you picked one up for the trip. Sounds like you may still be able to get the good guy discount!
No decided not to pull the trigger prior to trip. Ran fine all the way up and back (even with the heavier "parts" load on the way back). Figured I wait until I had some time to look it all over first, with this promo I may have just been pushed over the edge :)
Put the 35's on just to give them a try with the stock gears and no speedo adj for shift points. Seems okay on the road/highway but can tell that need to adj to allow for better shift points...then once I get the new axles/gearing it will definitely be a must.
JaySC
Anyone change out the axle, gear ratio, and tire pressure settings? Played around with these and a couple of error codes popped up. What are the benefits of changing those settings anyways? Any improvements in performance?
