RageKage
Not sure how far you've come on your build but if you're still looking for a tub, there are places I've found online that sell full fiberglass tubs and 1 piece front ends, or piece together front ends. Granted they are fiberglass so not sure if you'd like that much. Also a 350 will bolt right up to the existing motor mounts but you'll have a huge gap between engine and radiator. I have the stock engine in my 74 CJ5 and I have thought about doing the 350 route. They make complete kits for the 350 swap such as new mounts and wiring and fuel injection if you don't want a carb to mess with. As far as driveline you should be fine with just about anything that will mate to a 350, there's loads of connectors to bolt up a transfer to whatever transmission to decide on. Just gotta do some Google magic. I was leaning towards a 350/hydro 350 trans but I wanted to keep it a stick and as stock a driveline as I could. I believe just the mounting locations and driveshafts lengths is where things will have to be customized. I haven't looked in a while as my restore has been put on hold for a few years so I'm not sure how much has changed or been done away with.
