Shot in the dark, but retorque your track bar bolts. I have had so many random abnormal intermittent noises that were corrected by doing that.
If this did not fix it, I will definitely retorque the track bar bolts. I checked and the witness marks are still in line. I wanted to get to that today but with my injured shoulder, I just am having a tough time torquing anything. Thank you for the advice.
Yeah, I get that but if his pinion were actually loose, he'd be leaking gear oil out of the seal. Dicka pinion nut when it isn't needed could cause more harm than good as you are clearly aware of. Most people installing new yokes do NOT use an inch lb. torque wrench and tighten the nut to the proper preload. This is why so many people end up with friend bearings.
a loose pinion nut on my jeep. But I have seen loose pinion nuts on large axles that had yet to leak.
Gentlemen, I looks like I was able to fix it. I called Dynatrac earlier this week and spoke with "Z" and was told that the ProRock 44 axles come with a crush sleeve eliminator. He also advised, after putting me on hold and double checking with the technicians in the shop, that the pinion nut torque is 200 foot pounds.
Armed with this information, I finally got underneath RubySky and found that the pinion nut was about finger tight. I tightened it to 100 foot pounds and immediately the yoke was stable (no side to side play). I then, with my one good arm and my leg wrapped around that ever loving torque wrench, was able to tighten it to 200 foot pounds. I was spent after that simple chore.
QuicksilverJK and I spoke today and we both suspect that it was the crush sleeve eliminator that saved the day. I might have caught this loose pinionnut just in time. I must say I am SUPER impressed with Dynatrac axles right now.
And from a short 20 minute drive, I appear to have eliminated my clanking sound also!! Which makes sense given that this rotating mass coupled to a loose yoke would make this kind of sound. More driving will confirm later.
Thank you all so much gentlemen for all of your help. I greatly appreciate it!!
