wjtstudios
^^thats the way mine was too.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Option three:
Have them send you the kit, then have your local shop build the hoses and carry the builder kit as a spare.
Those ends are a mother to install. I have a builders set as spares and I tried to put one together in my garage for practice. Lets just say I need a lot more practice. :rolleyes2:
There’s a couple YouTube videos of it. I didn’t have too much trouble, locking the hose down in a vice helps a ton.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Yeah, I tried it as a field repair exercise to see how hard it was and it sucked. Now that I have a trail vise that would make it a helluva lot easier.![]()
For sure. Do you carry an extra line set on the trail?
2015 JKUR AEV JK350
1985 CJ8 Scrambler
I do, if you blow a line your screwed...
2015 JKUR AEV JK350
1985 CJ8 Scrambler
I carry caps for the ram lines. I’ll order an extra builder line set from PSC.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Something else easily forgotten is to have a spare belt. The PSC system has a longer belt and it's a really good idea to have a spare handy
I didn't realize it was longer but that makes sense since the idler pulley is larger. I know it was a bear getting the new belt on. It just barely fit.
Not a whole set - it's a repair kit and the fittings are a pain in the ass. I need to just buy a set of hoses.
I blew a PSC line on the trail one time. First order of business is to have a fire extinguisher handy. Hydraulic fluid sprayed about in the engine bay, including on the exhaust manifold. Thankfully it didn’t ignite. Secondly, I’d have either caps or spare lines, plus extra fluid. I had caps, which enabled me to remove the ram and lines, cap off the steering gear box, and keep driving that day and the next day. I also carry an extra serpentine belt.
PSC said I have my cylinder mounted too far to driver. That's the reason the hoses were too long. I pointed out to them that none of their literature gives guidance on where to mount the cylinder. I like where I have it. It's almost in the center. It looks good there and it is closer to the gear box so less chance for hose binding. It also works perfectly.
