We accomplished quite a bit today! Everything up to the ram is installed, including gearbox, new power steering pump, fittings and hoses.
A few notes:
The bolt kit associated with the power steering pump was quite confusing. No idea what all those bolts in the kit are for. They don't fit into the motor for mounting. The bracket that is supplied has larger holes than the factory bolts / holes / threads. And the bolts they supply are too big as well (diameter). so we reused the factory bolts. Keep in mind this is a 2013 - maybe something changed, I don't know. I will call PSC Monday to investigate. Since the factory bracket is thicker (aluminum) vs. the PSC bracket (cad plated steel), we had to cut down the factory bolts so they would not bottom out in the bore holes.
It is a bit hard to tell in the instructions, but I think when the reservoir was mounted next to the battery, you could keep the entire factory pressurized return line, and just add a longer hose to the barb on the return tubing. However, with the new reservoir mounted in the old factory position, that return tubing is too long, so we cut it and flared the end in an attempt to mimic the barb. We will see if it holds :fingerscrossed:
The feed line to the pump was simple, although we swapped the supplied 45 with a 90 degree fitting at the pump inlet to make the hose route a little better. You could make the supplied 45 work though if you had to.
Fittings at the gearbox went in no problem, although it sure is tight. Patience is a wonderful thing… Also the pump outlet line went right in.
So all in all it wasn’t too bad! Still have to figure out how to mount the ram.
Here are some photos:
New pump installed with our replacement 90, out of focus pressurized return line that ends up being too long:
Cutting off the return tube a few inches above where it converts from hose:
After cutting:
Flaring the tube:
Success (hopefully!):
Return line connected into the new reservoir:
Gearbox mounted and plumbed to the pump (ram connections have not been made yet):
Close up of the pump from underneath:
Looking up from the center out toward the passenger side at the pump feed (top hose in front), and the return line (top hose and tubing behind):
Looking up from outside the passenger wheel well. The dirty black housing above is what holds the air intake:
Another view from the same location, looking "southwest" at the pump connections
Oh and some coil over bling
