desertrunner
I think I see where the confusion is. The toe angle doesn't change with tire change, it can't. But yes the distance in front and in rear of the tires could slightly unless your toe angle is a perfect zero. Any toe in means imaginary lines aren't parallel, so measuring the distance between lines at different spots will yield different results. A 30 inch tire with 1/16" toe in compared to a 40" tire with no adjustment means the front of the 40 inch tires will be 5 inches further forward on the imaginary lines and slightly closer together compared to the 30s in the original location. Like the blue lines in the picture. Is that what you're trying to say?
That picture right there is EXACTLY what im trying to say with the fact that the bigger tires will be further down that imaginary line thus closer together so if you are measuring toe based on the outside of the tires like i was trying to do following Eddie's alignment write up, when you put bigger tires on there should be more toe in than the stock tires (probably by a very small amount).
