Primo82
Thanks for the tips, I have the corner tool but somehow I just couldn't get it to work right. I think I was using too much mud. And then I got frustrated and ended up just slapping more on trying to fix it. Annnnd it went downhill from there. Its still drying from round one a day later..... ::facepalm::
Inside, outside I so far am not having issues with there are also only 2 I'll need to do, and a crap ton of inside corners.
My biggest issue I think is just knowing when to stop and letting it dry, where it sits now im gonna end up sanding 95% of what I did the hell off and starting over. I know I got a good base layer of mud under the tape with no voids So I think I can leave the tape up and just fix the top. I'll be so happy when I can just paint and move forward.
Yea you really only want to lay a 1/8 to 1/4 thick layer of mud from what I have seen on each pass. And you pull most of it back off.
You should check on what is called hot mud or setting mud. You have to mix it from powder which is a bitch too but you can get some that sets up in 30 or so minutes so you can hit it again quickly.
Thinner is better, and plan for more coats. You can even water down your joint compound to make it go on thinner. My biggest headache with joint compound is how long it takes to set up.
If I were closer is just come do those for you! Certainly way less than I'm dealing with now.
