In a different thread on here, I posted about my TF coils breaking in and losing clearance on my rear speed bumps. I think that the way I park my Jeep makes the coils compress more and causes a permanent sag.
Would the Evo coils have the same issue? I now rotate my parking. Forward and backwards to spread the load on the springs.
Or I can park forwards and just get 4" in the back and 3" in the front hoping it all balance out?
Anyone else have a similar parking situation?
Eddie, what are you thoughts on my dilemma?
I have the AEV 2.5 kit with bilstines, a JKS front track bar, a Rusty's Rear Track bar, and JKS quick disco sway bar links.
I want to have as much flex as I can out of a coil lift and have a comfortable ride and be able to clear 37's one day if I decide to go that big. With the parts I have would it be more cost effective and practical to just buy a full on enforcer package and sell the entire kit I have or should I save some of the parts I currently have and just peice a lift together?
Wow! Looks amazing. Been wanting some of those. How is your drive shaft? Will you have to replace? I wonder if I don't do extreme flexing would I have to change out?
Thanks! They are great springs I wish I had pulled the trigger on them earlier! The driveshaft will need to be replaced sometime soon but Ill probably run it till I cant.
Profile pictures Sadly unless I can find someone selling for cheap or wanting to trade im stuck with the 33s I have for a while.
Ill just say it... If you are on the fence about getting these coils. Do it. :twocents:
Cheers :beer:
looks good man! now fill in those gaps with some 35's or even 37's! :rock:
Thanks!! I really need bigger tires just can't afford them
You will eventually. I still run the stock shaft but blew out the boot on the first trip post lift. That said I am still running it and will until it goes but you also have more crappy weather to deal with then I do. The mud, road salt and snow will do worse then the sunshine does.
I thought you had a teraflex kit. Did you change to plush springs?
