Here are few pictures of what I was describing earlier.
Here are two pictures of the upper mount I fabricated and installed for my rear track bar to move it out of the way of the rear passenger side coil spring:
Looking from below the track bar to the mount.
Looking even with the track bar.
Here is a picture of the lower track bar mount where it was rubbing on the drivers side rear shock. The new paint is covering the area that I ground down to provide enough clearance to stop the rubbing on the shock.
You can see I had to grind down the 90 degree angle that is originally in the mount.
Re-assembled after the grinding.
Hope this helps,
Matt
