Peak
Rockhard is a great cage, my only complaint is the rear section for a 2 door which doesnt apply to you lol.
What's the problem with the rear section?
Ahh thanks for the heads up. Is there any way to remove that piece when putting the top down or not having other passengers? I was thinking about adding the harness bar but only installing it whenever I go wheeling and storing when I'm not. Would this be a safety issue that you know of to continuously install and remove it? For both the rear bar and harness bar.
Posion spyder here. I do have one major complaint. If I have the hard doors on (which I rarely do) the cage moves slightly from side to side (when going down the road) and the cage hits the doors. Causing a very annoying rattle.
The Poison Spyder cage does not tie into the windshield frame. (The windshield is free standing with no support) it hits the door on the side panel toward the top of the dash. I can take a pic later were the powder coat is getting knocked off.Really? That would annoy the hell out of me. If the cage is bolted to the floor, the side of the tub by the doors, and the top of the windshield frame, how is it moving side to side? Where is it hitting the doors?
My OR-Fab felt solid as hell. It was a bitch to install, but I loved the look and it was quiet. I wish they still made them.
Good idea welding on the factory windshield support. I have moved my door hangers out a little also but it's still there. I am always running my bestop soft doors so it's not a huge deal.I asked PSC before ordering mine and they said they were working on something to address the window tie-in but did not have an estimate on timeframe or even what they were thinking to share. So I had the stock portion cutoff and welded on and then the frame tie-in added.
I misunderstood what you meant earlier. I also had the same issue with my side plate rubbing my passenger door. We just adjusted the door hinge out ever so slightly and no more problem.
