Rubicon Area Trails
bhaner
Niagara Rim is in the Stanislaus National Forest also and not too far away from Slick Rock.
Vic
That looks like a good trail as well!
I checked out the path to get from Slick Rock to there and found it may be a little further than it looks!
Speedy_RCW
My small group of 4 will be headed down on the 4th of July. Headed home the 10th. Hopefully we get to do everything on the list!
I am not a big fan of water crossings. SO we will see how it goes!
Hope you have a great time. If you don’t enjoy water crossings, Fordyce is not the one for you. Lol. Flows are currently very low and plenty passable though.
bkac
Is 2.5 feet passable? Not sure how much flow there is... But that still sounds like a lot.
The water is always deep, but 30” really isn’t that bad, it’s the flow rate that will kill you. 50 CFM is barely moving. I think 250-300 is max you want to try. There’s videos of 350 crossings. They are sketchy. It might be like 2’ now. It’s easily doable. I know the crossing into the dirty dozen was deeper then Fordyce. Just stay to the left on the first crossing for shallower crossing.
-AINOKEA-
I think 30” is the “limit” on a stock Rig according to Jeep... at least that what it was for a JK. I agree though, a high enough flow rate will sweep you right off the ground.
bkac
30” is for stock but I can tell you I very seriously doubt you could get a stock Jeep down to that first water crossing on Fordyce. Fordyce is big rocks and hard lines. 37s on that trail is the minimum I’d recommend in a 4 door. You don’t see very many daily driver Jeeps out on that trail. It has a much different vibe then the Rubicon.
wjtstudios
Ughh, someday. I’m on the wrong side of the country
2015 JKUR AEV JK350
1985 CJ8 Scrambler
fiend
Fordyce definitely is harder than the Rubicon. But it is doable with a JKU on 37s.
https://youtu.be/zPdINgAmIQs
Undertheradar
I'm running 71.5" wide Superduty axles with Machettes with 40s. I'm right at 89-90" wide and I squeezed through. The front I was able to just wiggle through and the rear I made go through. Had a guy with stock Rubicon axles and he made it without touching. Then another one one 68.5" wide Curries and 40s and he made it through with no problems at all. He is around 86" wide.
I’m running Super duty’s as well with 42’s (14.5’s). Thinking of putting on a set of older 40’s (13.5’s) to squeak through the gate.
dillard09
You should. It's a beautiful and fun trail. Couple pics of the trail.
I dont have any pics of me squeezing through the gate but that pic is 68.5" axles on 40s and Trailready BL. He had room to spare.
OverlanderJK
Resident Smartass
This is the water level at 380.
This is it at 1200ish. Notice how much more there is.
I wouldn’t recommend crossing at over 300. Not that it can’t be done, it just isn’t fun. 200 is more fun cause you aren’t worried about anything bad happening.
Speedy_RCW
I crossed Committee at about 380 and it was pretty gnarly. And that first crossing is a lot deeper than it looks. For me it was the least intimidating but I took on the most water in that one.
OverlanderJK
Resident Smartass
I agree. Seems like that one always gets the most water. No way I would cross committee at 380. I was there when it was like 20 and that’s more my style. Lol where I can see the bottom and it’s only ankle deep
bhaner
Another awesome trip in the books!
The area didn't disappoint!
I enjoyed Fordyce trail the most. In fact it may be my new favorite trail bumping Pritchett Canyon to the #2 spot! Winch hill #1 was EPIC! Sitting at the bottom I wasn't sure I was going to make it. The big rocks and steep incline are a bit intimidating!
The Rubicon was fun but only one section was a challenge. That was the "Old Sluice" area. That was fun trying to fit through! A few in our group messed up their tops on a rock. Somehow I just barely got by! Next time I want to run it uphill! I could see how the big sluice would have been more fun if it wasn't filled in with all the small rocks. I didn't even notice we were at it until I was already through.
Some Rubicon Pics:
