suicideking
is the only problem that the shaft will not slide throw the sleeve? is it possable to drill it out the little extra to get the safts to fit!
You're risking damage to the areas you drill, probably the tubes. Crack or damage them and the whole thing is worthless.
There are other locker options, I'm just not sure what they are (other than Ox which would probably be good). Sounds like ARB is the only one that we're sure won't work (so far). If you can live without an ARB, might still be a good deal. Might try to see if he'll sell for $2K or less.
