I also had some time to work on the track bar which I have been meaning to do since I got my jeep. Whoever installed it did a poor job because it came into contact with the bracket. U can see when the collar use to contact the bracket.
Now that I fixed the problem I am hoping I didn't create a new one....
With the collar turned around and not contacting the bracket am I going to run into any problems with the bolt or collar contacting the steering stabilizer when articulating?
I might be able to turn it a so the bolt is pointing up a little more but wanted to get some feed back.
well i was the lucky winner of the slabs that were up for auction. Thank you Jake. we will be organizing a time to pick them up next week so that i can hopefully check out his new upgrades as well as finally make a visit at ORE and see where all the magic happens.
Hopefully sometime soon i will have the new to me slabs and Nittos mated together. any advice for someone mounting beadlocks for the first time? will i need to get new valve stems or all new mounting bolts?
You shouldn't need new valve stems unless they remove them for some reason. Just get a couple 5 gallon buckets, one to sit on and one to put your tire and wheel on. I think Mel did a video of mounting up a set, you may be able to find on here or YouTube. I started all the bolts by hand then used my cordless drill to zip them in on a low torque setting. Once they were all snugged I bumped up the torque setting and went in a crisscross pattern until my drill wouldn't torque them any further then switched to a standard torque wrench. Think I started at around 17 then up to 20 and finished at 23. Main thing is to make sure you get the tire bead seated down into the wheel shoulder and get the ring tightened down straight and uniform.
Thanks for the reply. Yea I have watch Mel's video a few times. Just a little nervous but excited on attempting it myself. He makes it look so easy and after talking with Eddie he reassured me..... Well, it's not as easy as Mel makes it look. Haha.
I have had this rugged ridge CB radio bracket laying around for awhile so I thought I would throw it up since I had some time today. The install was super easy straight forward. Now to see how well it works.
Nice I have the same mount and CB![]()
That's an awesome, simple mount. If I ever ditch my cobra 75 set-up, this is likely what I will end up doing. Where do you route your power and ground up there? Through the top windshield panels?
Yes I have my routed down the windshield panel. Makes install simple and clean.
