Lol I don't even need to comment on that.
:thinking: :shock: :crazyeyes: :cheesy:
Grew up pulling barbed wire with a hi-lift. I'd only use one to lift a vehicle if it was the only option avail and in a level parking lot. :cheesy:
I prefer a BJ to gettin' high any day. :thinking:
For off highway recovery work I keep a few 4 ton come alongs in with the recovery gear. They aren't as versatile as a hi-lift but several order of magnitude safer & perfect for setting up shifting pulls or to steady loads.
Not trying to take anything away from the awesome of a double hi-lift setup though. Sicker lookin' than a snorkel any day. :rock:
A Hi-Lift is probably one of the WORST tools to use to change a tire. Unless you strap up your axle, you have to lift your Jeep dangerously high just to get the tire off the ground and being that everything is held up by an unstable iron stick, the chances of someone getting really hurt is very high. Also, if you're not careful, the jack handle itself can be an extremely dangerous piece of steel tube that can fly at a tremendous speed if it were to slip out of your hands. I have seen guys get seriously hurt from this. When it comes to changing tires, a good bottle jack is a far superior and safer tool to use. As far as using it as a come-along, that is one of the few really useful ways that it can be used but, a good winch will do the same job better and safer. There are instances where a Hi-Lift is a good recovery tool to have but more times than not, I they are just used to make your Jeep look cool or are incorrectly used to change a tire.
Got ya. At home I have a 3 ton floor Jack. And I have a bottle Jack that I carried in my TJ before I got the hilift. I guess it would hurt to put the bottle Jack back in.
