Arrcherr
Just need the hot dog steamer or small frozen pizza oven.80" flat screen, fireplace, wet bar, 60's Fender Twin Reverb, keg with tap, dart board, oh and some tools...
I want to insulate it but I like having the studs exposed. Way to insulate but do drywall between studs rather than over it or something?
Leave it open. Picture of ours below. Insulation is stapled on. Most comfortable garage I've ever worked in(with no heater), and we've had two visitors comment on how comfortable our garage feels. (Garage faces west if that makes a difference).
I like it. Maybe a combo of these two. Insulate it as Doug has done but then finish it with some thin plywood between the studs. Gives me more surface area to hang things on. That second step could come later though.Could you use a big piece of plywood instead of drywall, seems like it would be more solid to attach stuff to?
Doug, estimate to insulate as you've shown?
You may be on to something...Maybe just keep things simple...
Or re-evaluate priorities
Yeah, seems easy enough to do and gets stuff up and off the floor.I like this !!! Might have to do it in my wood shop.
Edit: wrong picture [emoji17] I meant for tube wood storage that's above this one
Not opposed to this. I mean, you got your spinner rods, 2 per person, than your fly rods, 5 weight, 8 weight, etc, then you got your spear gun, then you got your nets (plural), then you got your deep sea rods...and that's not even accounting for the giant swordfish mountYou'll need to reserve one entire wall to fishing rod storage...I would...
New idea: pressure washer system. At least sitting in the garage, if not plumbed into it permanently.
