Scott's build of a 1981 CJ8 Scrambler
wjtstudios
Awesome Scott, I missed the start of this yesterday! Congrats on being part of the scrambler family! The horn definitely is operated by the center of the steering. When that pressure sensor goes it's a bit of a project disassembling the steering wheel to get it. If it's the wiring inside the column that's a whole different battle. Were you able to track it down?
GraniteCrystal
From what I've read, it looks like an aftermarket steering wheel. I'm guessing when they put it on they just didn't bother wiring up the horn or rid it incorrectly. Either way, I have a working horn, it's just not the steering wheel. So it's moved down on the priority list till I take care of some other things.
wjtstudios
On the OEM, there's no need to pull it to replace the horn, it is mounted above in the sequence of parts. That does not look like a stock wheel so I'm not sure there. I agree on moving it down the list. I've got a whole white board set up in my garage for each jeep with repairs like that have been sitting for years!! There's never enough time in the day!
aTX427
So cool. A beautifully restored one with a pickup bed / hard top just showed up in my neighbors driveway. I was like ...what's ...up?
GraniteCrystal
Put together a build list for Atticus with links. All suggestions welcome. I'm really encouraged that the total for the first list is only around $750. The second list will be partially funded by selling the current tube doors (got a buyer lined up already) and the hardtop.
Necessary upgrades
Spare tire and wheel
https://denver.craigslist.org/wto/d/chrome-wheel-jeep-dodge-ram/6192293444.html
Catalytic converter https://shop.advanceautoparts.com/w...hTerm=catalytic+converter&searchedFrom=header
Two universal seat belts for the front
https://www.summitracing.com/parts/HFM-SBHP/
http://www.seatbeltsplus.com/product/Q8291P.html
http://www.omix-ada.com/universal-3-point-seat-belt.html
New draglink or at least the ends
http://www.omix-ada.com/hd-tie-rod-drag-link-kit-72-81-jeep-cj-models.html
New tie rod
New breather hose for front diff (check rear diff too)
buy from OReilly down the street
Gear oil
best kind for older gears?
Motor oil
best kind for older engines?
Shifter boot
http://www.omix-ada.com/dana-300-transfer-case-shifter-boot.html
or
https://shop.advanceautoparts.com/p...t-18606.05/10185270-P?searchTerm=shifter+boot
Enhancements
Sport Cage
http://www.rockhard4x4.com/product_p/rh-1005-a.htm
Soft top
https://www.bestop.com/jeep/1981/sc...ow-color/tinted/doors-type/no-doors-included/
Body mounts (which ones to get?)
http://www.omix-ada.com/body-mount-kit-black-81-86-jeep-cj8.html
http://www.omix-ada.com/body-tub-mounting-kit-41-75-willys-jeep-models.html
http://www.omix-ada.com/body-tub-mounting-kit-76-86-jeep-cj-models.html
YJ half doors
New dash plate or something to plug the cd player hole
Ddays
Yeah, seems to be the consensus that it should be in the steering wheel. Looks like an aft steering wheel which wasn't properly installed.
This be is gonna be cool to follow!
That steering wheel looks like its made by Grant. I had the exact same thing on my old 77 Ford pickup. If you pry off the cap there should be the same horn ring under it that is pushed up by a spring. Mine used to pop off all the time and the spring would fall out allowing the horn to blare continuously until you could get it assembled back in place. Quite fun while you were looking for the stupid spring rolling around on the floor somewhere and EVERYONE is looking at you like WTF man? :cheesy:
GraniteCrystal
Yep, that's what mine looks like. So maybe the purposefully didn't wire it up. I may wait and see if I can find a stock steering wheel and wire it up to that.
GraniteCrystal
Anyone know if I need a whole new drag link or I can just replace the joints somehow?
Tempting to just do the $330 package for drag link and tie rod but I like keeping the stock parts if I can
BananaJeep
Good stuff so far, Scott! Glad you were able to pick this up. Looking forward to seeing it build up! :thumb:
