Should I Relocate my Tag??
  • Total voters
    13
  • Poll closed .
USMC Wrangler
What relocation bracket is everyone using? I found that JCR makes a bottle opener to cover up the hole.
I used the same components listed below.
[emoji1303] I used the RockHard set up and a Poison Spyder fill plug. The lights could be brighter imo but it does the job.
The license plate light seems bright enough for me, but I agree the 3rd brake light is a little too dim.
notnalc68
That dude from Mississippi
I relocated it, and used the ORO tag light, and RockHard 4x4 license bracket. The ORO tag light is a little dim, but it's a light.
I ran the ORO wire, down the tire carrier, and under the Jeep. I stuck it through a hole in the bottom of the passenger side corner. I ran wires to the third brake light wires in the rear door, back into the Jeep, and drilled a hole in the corner, to run them to the ORO harness. I used rubber grommets in the holes. The third brake light wiring was reversed from what the ORO pamphlet said, and black was hot and not the ground wire.
AZ Explorer
I voted and then read the thread. But since you did the relocation, I still feel like my vote counted. :D
Looks great and more balanced.
