Spring retainers
sassmouth
I assume that it does correct the bow in he coils. I am debating if this is worth installing for me since I am planning on adding long adjustable arms anyway. I can correct the caster and maybe get rid of the bow at the same time. Do you run stock or adjustable arms with these?
yes it corrects the bow plus a spring was rubbing on the track bar. I have Synergy adjustable control arms to correct the pinion angle.
JKbrick
^^^ caster is the front but these take the bow out of the spring and adjustable upper rear arms correct pinion angle. I have a new set of the brackets I didn't use if you need them
TorXd Out
