My steering wheel will be straight then after a turn it will be off is that the drag link?
Yes. Like others said, if once you've adjusted the steering wheel by turning that sleeve then tightening it down, it still goes off-center then the threads are probably stripped and needs to be replaced.My steering wheel will be straight then after a turn it will be off is that the drag link?
Should the amount of threads exposed on both sides be the same?
