Stiffer springs
Derrick_Merwin
I am interested in buying a new bumper and winch for my jeep I don't want the front end to sag but I do not want to lift it yet what spring rate would be good to support the added weight I'm not interested in getting a ton of lift from the new coils just want them to support the added weight also should I just get new front coils or all new coils I'm not putting a new bumper on the rear
kaptkrappy
I vote for leveling kit. 2 inch's in the front and 1 inch in the back for now.
or
A couple of front coils off a 4 door JK would put it back to the stock ride height if that's all they want. (nobody wants that)
I see he has a 2 door in his avatar, probably got 14 or 15 front springs.
Swap them for 17's or 18's and it's all level again after the new bumper and winch.
pvanweelden
if you want tofind out what coils you have in the front- if the tag is still on the coils, you should see it easily, you want to know the last two #'s before the AB or AC. ie- 52126313AB would be a 13.
The higher the number, the taller the spring/and stiffer rate.
