JKUndaunted
And I would like to apologise once again to everyone for blowing my top.
Sent from my GT-I9300 using WAYALIFE mobile app
3.5-4 is about the max before you fight caster/pinion angles w/ a stock axle.
Only if you are running the stock front drive shaft with single uj at front and Rzeppa joint at the t-case Or an aftermarket front driveshaft with the single uj at the front and double uj at the t-case as you must keep the pinion and driveshaft in a straight line.
Good luck with that lol
A straight line is impossible unless you can deal running 0 caster angle. In 2wd the shaft is not under load anyways. Regardless, but more so with a aftermarket shaft .. It's a fine balance. Some never seem to get rid of DL vibes especially with deeper gears.
Prorock FTW
Prorock FTW
Oh yeah and I would love a front prorock 44. I cannot begin to comprehend the shipping cost and import duties.
Im not quite up to the standard of the dynatrac guys. Maybe I could buy it in pieces. Hahaha.
Just need a 12 volt battery, jumper cables and some bailing wire and you got grade z welds!
Sent from my whatchamacallit
Hey I can do better then that. Mine have been rated at an outstanding grade Y. :thumbup:
Lol almost duct tape quality!!
Now I can tell you that I have never had a weld break out on the trail. Only when parked up overnight!
If you can cut your welds off with a wire brush your doing alright. :thumbup:
