BaddestCross
Yes. The poly stops barely compress effectively making up the difference of the pucks I removed.You want as much bump stop as lift, no?
I have seen the light panel before. Very nice! Love the tire cover too!Okay, realized I didn't really document the aux lighting I did and since I had to redo the rear, I figured I'd post it up in this thread in one post...
Apollointech switch pod installed and had some custom covers made for the rockers...
Rock lights and scene lighting
Front amber dust/fog lights
Rear chase lights with adjustable flash pattern (2nd photo shows button to change pattern)
Rear work/backup lighting
Yes, I already have a winch and lockers.
Thanks... It's an Xprite G2 series. It seems to be built very well. The one I had before was their base model and after one day blasting through the desert the vibration killed most of the LEDs. Hopefully this one will do better.I have seen the light panel before. Very nice! Love the tire cover too!
Thanks. Every time I look at my switches I smile which is basically the whole philosophy of my build.I love that custom rear light switch cover. I may pick one of those up.
Yeah... It could've been a lot worse. I'm thankful that nothing dropped down into the cylinder and that my guy was able to fix it without pulling the head.That blows regarding the sparkplugs but I've seen that shit many times before. Tech's need to slow down and do it correctly.
I use "fuck" for a comma, so I really couldn't tell you.Dam... How many times did you say “F&@k” when that happened? ... Glad it worked out.
Welcome to WAL. You should post up an introduction in the Wave forum.And I thought I was the only person shit like this happens to. I got where I hate to do simple stuff because it winds up costing me more than if I would had let someone else do it to start with.
Sucks about that plug. I had an F150 with those dumb 2 piece plugs on a 5.4. You just assumed about half would break. This is what this reminded me of.
If you don’t mind post up a long term review on that coil. I will probably be doing this within the year.
That was a stupid design. Luckily I never had to replace mine in my f150 but I was worried about it.
You got that right. I do enough of my own dumb shit... I don't need to put up with other people's dumb shit.Man that sucks, my threads on one of plugs was crossthreaded when I replaced them last year. There's always one! Glad you got it fixed. There's so much pleasure fixing the dumb shit and knowing it's done right.
