ColeHanlon
Right? I wasn't really expecting much, but I'm not complaining.
Been hearing and feeling a clunk from Fiona's front end when I hit the gas from a stop... Started feeling another one from the rear yesterday. I crawled under and started putting my hands on things to see if I could figure it out and found that I could wiggle one of the front and rear control arms. That's not good... My first assumption was blown out Johnnie Joints since I never did rebuild them before I had the new-to-me arms installed a few months ago. However, on a whim, I figured I'd check the torque settings on the bolts. Bingo! Way loose! I checked all of the CA bolts since I was under there and found only one that was to spec.
Moral of the story, torque your bolts boys! [emoji6]
Yeah, I was wondering if Locktite was a good idea on the control arm bolts... It doesn't look like the guy that installed them put any on there.Loctite too.
I hear tell that the change oil notice will change according to driving conditions. Mine averages about 3000-3500 miles. No low oil indicator came on so I was really surprised how little oil dumped at my last change.Timely post. I recently noticed more than usual as well, 08 Rubicon. I also had the oil change light come on at 2400 miles, which is very abnormal as I have been going over 5k regularly. I know it got reset last change so was wondering if it was a system fluke.
Sent from my SM-N910V using Tapatalk
I have just under 137k on mine. I bought it August of 2016 wothb92k and barring my first oil change being low, which I figured may have been them forgetting to reset it, I have gone about 5k between indicator warnings. My driving style has not changed drastically, though I did add new slightly larger tires since the last change, along with a procal change to the tire size, coild be the culprit as my driving style has mot changed, still about 1100 miles a month.I hear tell that the change oil notice will change according to driving conditions. Mine averages about 3000-3500 miles. No low oil indicator came on so I was really surprised how little oil dumped at my last change.
The reading I did regarding oil consumption on the 3.8L showed that Chrysler considered 1 quart per 1000 miles "in spec" which seems crazy to me. I understand the early JKs had issues with bad rings which caused a lot of blow-by back in the day but it didn't affect all of them. I figure that if the engine reached 100k with negligible oil consumption that the rings are fine so the PCV seemed like a likely culprit. I hope I'm right.
My engine runs really well for such high mileage and after I replaced the plugs and distributer it idles really smooth and has a lot more power. I don't get any smoke out the tailpipe, and as I said before, the plugs - though worn - didn't show signs of any major fouling. So unless the Seafoam deep soak fucked something up, I'm fairly sure that the PCV should correct it. Particularly after seeing how much oil was in the tube and around the old valve.
How many miles do you have on your Rubi?
Yeah, I probably drive about 1500-2k per month combined high-speed hilly highways and low-speed rock crawling so I'm running the RPMs pretty high in either case so my indicator comes on anywhere from 2500-3500 miles. Since the regear, it's not pushing as hard on the highway, so I'm waiting to see if it will learn and adjust.I have just under 137k on mine. I bought it August of 2016 wothb92k and barring my first oil change being low, which I figured may have been them forgetting to reset it, I have gone about 5k between indicator warnings. My driving style has not changed drastically, though I did add new slightly larger tires since the last change, along with a procal change to the tire size, coild be the culprit as my driving style has mot changed, still about 1100 miles a month.
The PCV sounds a good option, simple as hell to do and cheap to boot, so I ordered one as well after reading this, $12 shipped. Can't really go wrong, and like I said, timely post, glad you put it out there. [emoji106]
Lol. At least you have a goal.James, at some point I’m gonna need your post-100k maintenance parts list. In about 8 years. [emoji23]
Messing with a few piddly issues this last week... CB antenna mount on my tailgate broke, so I'm relocating it to my cage and making it a dual-purpose antenna for the stereo as well so I can remove the useless factory antenna.
Got the dreaded "gas cap" warning and the gas cap isn't the issue this time. As I was looking for an obvious break in the EVAP tubing, I realized that the axle leak had gotten much worse and has puked diff oil all over the wheel well and brake rotor. Good thing I ordered the new axle shafts, but now my hopes of hitting the trails next weekend may be shot. [emoji22]
Maybe... Have to check the schedule. Ely is out of town the weekend of the 1st, so I was actually trying to go out and camp for a night or two. Not sure that'll work now unless the axles are delivered before Friday.How about June 9-10?
