Few updates on the DW issue. With very little time after work everyday I can only do so much.
Got a new grade 8 bolt to try and account for a larger hole in the frame mount if it was infact wallowed out. Doesn't seem like it's any bigger than the stock bolt, but the size is 9/16th.
However the new track bar still moves like it did even with this larger bolt. After this I re-torqued everything!! All front, rear, upper, and lower control arms. Did find a few slightly loose which doesn't surprise me entirely since I haven't re-torqued since the axle swap. The worst bolt was frame mount rear track bar. This was very loose and had play before I torqued it back up.
Also found this:
Driver side, frame mount, upper control arms
Passenger side same bolt
Does anything with the bushings look like it needs to be replaced?
Also checked the ball joints..... passenger seem fine but drive have a slight play. Not sure how much without a dial indicator. But I remember a write I believed Eddie did and said something like: if it moves enough to see it then it most likely needs to be replaced. Can anyone confirm this?
Lastly I checked the toe in measurements.
Front part of tire: 68" 13/16
Rear part of tire: 69" 1/8
By my good friends, jeepjeep75 calculations. I have a toe in of 1/4" and it should only be 1/8". So I'm too toed and basically cross eyed with my front tires. I should be getting my new tie rod ends tomorrow so I'll work on adjusting the toe maybe Friday.
All feedback and thoughts are welcome! This is hard to diagnose alone!!
Sent from my iPhone using
WAYALIFE mobile app
