OverlanderJK
Resident Smartass
I ended up putting a new EVAP Module in and was able to clear the Engine light. I've run two tanks of fuel thru it an it hasn't come back on. But the permanent code and the GASCAP display is still showing up on the dash. How long does it take for that permanent code to clear? Is there a reader that will clear a permanent code?
If that cleared the code and keeps it clear, the permanent code should clear out after a set amount of miles. At least, that's what I recall.
None of that worked for me. I found online it said to turn the Jeep on and let it idle for 30 seconds, run the jee above 30 for five minutes, stop and let it idle for 30 seconds before turning it off. I did that once and it worked perfect for me.We ran into the same thing with our JK. A PERMANENT small EVAP code just wouldn't clear even after we fixed it. Ultimately, disconnecting the battery is what we had to do. Working in the automotive industry, this is the first vehicle I can recall where I had to do that. Normally the scanner will clear it.
