Fixed annoying weld slag rattle in lower RockHard Cage! Drilled a 5/16" hole in the tube end and out came several tiny pieces of weld. [emoji6]
Lol! Now you know what you must do! Or go nuts...the choice is yours.Been dealing with the same slag rolling around since I installed mine. Never really thought of drilling a hole [emoji849]
It's was totally an OCD moment. Worth it to keep me sane. [emoji51]Wow. Now that is OCD ! Awesome to hear you took the time to fix it. :thumb:
Had to completely remove it. If you decide to do this on your Jeep, make sure you loosen the top bar clamp bolts on both sides. The top bar pinches the windshield frame when the clamps are tightened causing the bolt holes to no longer line up correctly. Loosening the bolts will make it much easier to remove and reinstall the upright bar bolts that go into the upper windshield frame. I learned the hard way and cross threaded one of the bolts. Luckily I was able to clean up the threads with a tap. PITA!!So crafty. Were you able to just remove the crossbar?
I'm just getting used to my pebble sound though. Lol.
Lol! So true...
I should have known this would happen! Lol!!Well, looks like another bullet for the list of projects I have waiting for you. Lol.
Thanks! It was a nice day to run to the local mall. Lol [emoji41]SWEET!! Nice to see you getting both your JK and Renegade out on the trail :thumb:
