So I'm sitting there looking at my truck-96 ram 4x4, then at my jeep-'10 JK sport, truck has d44 front, jeep has d30 front, truck does not offroad,(except some forest/ fire roads), jeep does , so can the axles be swapped? and is this feasible in a cost effective sort of way?
If you decided to swap in the non-jk axle (basically a junkyard axle), there is so much cutting/fabricating/welding that you would be way better off just getting an axle from a junkyard so you don't have to mess with your dodge. It's not worth it at all. (You would spend way more getting your jk d30 to work in your dodge, than you could just get a d44 from a junkyard for.).
Some other things to think about- the gearing is likely not correct for either truck, like Eddie mentioned, the tone rings, bolt pattern, width, new suspension brackets, steering (some trucks have a longer pitman arm than jeeps meaning you won't have full turning radius without a longer pitman arm) new driveshafts for each truck, and... You would have BOTH of your rigs out of commission at the same time.
Still, a very good thought, IF it was that easy.
