Elroy231
Mistress 2.0 is lookin great. I must have missed when you got the wheels. Damn I like those. Sure is making a come up.View attachment 361477 coming along.
I like. nice looking JeepView attachment 361477 coming along.
Geez. That sucks.Of course I ordered the wrong fender and started to paint them before I realized it.
Bummer.Of course I ordered the wrong fender and started to paint them before I realized it.
BummerOf course I ordered the wrong fender and started to paint them before I realized it.
Oops I meant fender liners. I ordered the evo vented for coil spring suspension when I should have ordered the ones for coil over suspension.Bummer
What did you order?
That makes more sense. I was curious what fenders you would have ordered. I’m sure someone would buy the ones you have.Oops I meant fender liners. I ordered the evo vented for coil spring suspension when I should have ordered the ones for coil over suspension.
Order the ones for coilovers, trace a pattern where they cut the extra material on the coil spring ones, then send me the ones with the lines traced on them & I'll cut them out & put them on my jeep... Everybody winsOops I meant fender liners. I ordered the evo vented for coil spring suspension when I should have ordered the ones for coil over suspension.
It's not just the center section on the JL. The coil perch is huge and the back section routes around that from what I can tell.I think you can buy only the center section to swap in for the coilovers.
Refresh my memory on what all you put onJeep is finally up and drivable. I took it down for an alignment just to see how close me and MericaMade got it.
I still have a pull to the right and cant figure that one out. Any of you degents have any thoughts or guidance?
Pulling could be a tire issue but usually it's a caster problem. Pretty difficult to do on a solid axle. If camber is extreme enough, it can cause a pull, but again on a solid axle, it's unlikely unless you have really fucked up bearings or ball joints. Thrust angle can cause some weird symptoms too.Jeep is finally up and drivable. I took it down for an alignment just to see how close me and MericaMade got it.
Damn sexy rig my friend!View attachment 361477 coming along.
My entire wallet.Refresh my memory on what all you put on
This is a good point. I can adjust caster when evo decides to ship out the control arms. Hopefully this year.Pulling could be a tire issue but usually it's a caster problem. Pretty difficult to do on a solid axle. If camber is extreme enough, it can cause a pull, but again on a solid axle, it's unlikely unless you have really fucked up bearings or ball joints. Thrust angle can cause some weird symptoms too.
All it takes is moneyDamn sexy rig my friend!
