The Ultimate TRUE TIRE SIZE Database
Stephane87
Ok so if my lift says maximum 34” tires, do I buy a tire that says 34” on the side or one that’s about 1.5” taller (then my he side specs) like 35”-35.5” knowing that in reality it will be smaller?
As I said in your other thread, you want what's stated on the sidewalls. Yes, they will be SMALLER than 34" but they will be correct for your lift.
onlyone
An almost perfect measurement can be had for you new tires with this equation.
Find your Revolutions per mile for your tire. You can find that at tire rack etc.
Here’s an example for a standard tire people use here.
315/70/17 BFG KO2.
604 revolutions per mile
5280/604=8.74x12/3.1416=33.39” tall
Works pretty dang good.
Sorry it’s a little off topic. Just thought it might be helpful.
Stephane87
Can someone tell me what would be the real size of a Toyo Open Country AT2 Extrem in 285/75R18 and in 295/70R18?
Thanks a lot
TheGrendel
Yokohama Geolander MT 003 35x12.5R17 mounted on stock Recon rims.
30 psi less than 20 miles.
33 3/8 all the way around to top shoulder tread.
I will say these are actually better riding than the original BFGs. Pretty cool to compare them on stock suspension and get and apples to apples comparison.
Joeycook45
285/70r17 Mastercraft MXT?
I’ve been searching for a few weeks and no luck, can anyone tell me the height of 285/70r17 Mastercraft MXT’s?
According to their own website, their 285/70R17 is 32.91 inches in diameter (off of the vehicle with no weight on it). This is nearly identical to every other 285/70R17 tire out there. So with the weight of the Jeep on your tire, you'll likely have a total height of slightly under 32 inches (you can find several of that size tire in this thread).
http://mastercrafttires.com/Tires/Light-Truck/Courser-MXT.aspx
Joeycook45
Lol thanks for the PowerPoint. As stated in my post I’m aware what the specs say but this thread is for real world actual measurements and that’s what i’m Searching for.
What I'm saying is that the tire that your interested in has near identical specs to the other 285s out there according to various manufacturer's websites. So if you browse through this thread and look at the ACTUAL height of all of the different 285s, you'll find that they are all right under 32inches. So the tire that you're interested in will probably be about the same.
