GP NOIR
Thor’s Lightning Bolt Compressor
We picked up a Thor’s Lightning Bolt Compressor at the SLC Off-road Expo for a special show price of $220 out the door. It’s portable and comes with a carry bag and an air hose for airing up tires. The air hose is fitted with an air gauge. The compressor has a one year warranty.
PRO-
-It’s fast. I didn’t time it airing up a set of 35s from 12 psi to 37 psi, but it was faster than my ARB Dual Compressor. Fast enough that if you don’t keep an eye on it, the tires will soon be overinflated.
-Price. Retail is $239.99. Roughly half the cost of an ARB Twin Compressor by itself. The ARB portable compressor kit (which includes a couple more items such as a 2 gallon air tank) is close to $1,000.
-It’s easy to set up and use. Connect the air hose, connect the alligator clips to the battery and turn it on.
-It feels solid and looks well made.
CON-
-It’s bigger than the ARB
-It runs hot. To be fair, ALL compressors get hot. I noticed it particularly with the Thor’s because it was hot when I had to stuff it back in the bag.
-It seems to not have a pressure switch. The ARB shuts off when the system reaches about 145/150 psi. The Thor’s compressor didn’t shut off when it reached full pressure. Maybe I didn’t let it run long enough, but I didn’t want to risk blowing it up.
-The carry bag is flimsy. When I picked it up by the handles, the bag ripped. The zipper broke after being used a couple of times.
-Hose connectors are of an uncommon type. They don’t fit the more commonly used industrial, automotive or universal fittings. If you plan to only use Thor’s inflation hoses, this isn’t an issue.
FINAL THOUGHTS
For someone wanting an economical air compressor with impressive air flow, the Thor’s Lightning Bolt Compressor is worth considering. It fills tires faster than the ARB Twin, an amazing feat at its price point. Run cycle is, I believe, a half hour.
I have no affiliation with Thor’s other than speaking to them at the Expo long enough to be talked into buying a portable compressor for my wife’s Grand Cherokee
PRO-
CON-
FINAL THOUGHTS
